Posted by mkirsch on August 20, 2013 at 05:12:30 from (64.80.110.75):
In Reply to: Farmall Cub posted by Two Banger on August 19, 2013 at 17:48:30:
I can't believe there's enough material in the block to bore a Cub engine out to 3"!
You'd be well into the water jacket, and there wouldn't be much more than a thin sliver of metal between the cylinders.
AFAIK, .060" over is about as far as you can go. That would make for a 2.685" bore, far from 3"
Are you sure you don't have an A or a Super A there? People commonly mistake one for the other, especially if they're new to tractors.
An A/Super A is about 1/3 bigger in every dimension. The Super A will have TWO hydraulic levers instead of one. The A/Super A will have the serial tag under the seat vs. on the steering bolster for a Cub.
If you truly have a Cub with a 3" bore, there are a lot of people on here that would like to see pictures. Whoever did it was either a total hack or a master engine builder.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
