Posted by Janicholson on July 28, 2013 at 17:38:13 from (74.60.94.18):
In Reply to: Front end wobble posted by John17 on July 28, 2013 at 17:04:37:
Toein should be 3/16 to 1/4" from front to rear of the tires. Measured with the tractor pushing on a 2X4 so there is some pressure pushing toward the rear. Before measuring, lift the wheel and use a jack stand or concrete block to hold a nail steady to scribe a line in the rubber of the tire to measure to (spin the tire and scribe it) Next is the spindle bushings in each side of the axle. These can have as much a .005 or so play when the load is taken off of them. If more, it will be tough to keep wobble at bay. Then tierod ends on each side. Then the steering bolster and its bushings. Next the sector gear and worm in the box need to be tight. Then the U joints in the steering shaft. The archives have many clear descriptions on these repairs. Jim
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
