hydraulic fluid
Posted by 350 dave on April 19, 2013 at 12:17:09 from (50.48.53.134):
hi had trouble with hydraulic systems last winter.
fluid very milky and screeching noise every so often, also leaking with squirt just below right knee. i think the valves are all good now.
how to get all the milky fluid out. should i take it all apart? or just drain and add new?
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that’s wha ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
