A leaky or stuck relief valve can mimic a bad pump. A pump wears around the edges of the 8 shaped housing. Often the wear is so smooth that it does not appear worn. Using a feeler gauge between the gear tips and the housing there should be less than .001" measured in all directions between the tooth tip and the housing. There are no rebuilders that ai know of due to the housing being worn as well as the gears there is little to actually repair without as much expense as making a new pump. Jim
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
