Posted by LonM on March 12, 2013 at 17:28:43 from (69.165.30.73):
In Reply to: 620 drill posted by Robert23239 on March 12, 2013 at 15:34:57:
I have no experience with a 620 but we have a 6200, just a little newer version of a 620. They work well for small grains, and i've planted small cover crop seeds and been satisfied too. The front double wheels can fall off if you don't keep the bolts tight where they attach to the swivel (neighbor ran over his wheels with his drill, i've heard of others too but we have never had a problem). I do not think that our 6200 is built as well as our old IH 100. The seed cup levers are thinner, the plastic idler sprockets will break if the chains are too tight, the seeding rate lever is a not as heavy as the one on the 100, and I am not happy with the acre counter. Also, the rockshaft assembly should have some bushings in it on the outer ends instead of just fitting loosely in the stamped frame rails- the rockshaft will deflect over time. Do not let any of this scare you- I think it is still a pretty good drill. But they were a little light for the amount of seed they can carry. They do a good job though. Make sure the opener discs make a V and not a W, which indicates excessive wear and disc replacement in the near future. Hope this helps, LonM
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
