Hitachi alternator/voltage regulator help
Posted by PoppinJohn720 on December 30, 2012 at 21:02:46 from (98.22.154.120):
Guys, I'm trying to help my father in law figure out a current draw problem in his 54 model Cub which has been set up with a small Hitachi alternator and what looks like an old Ford four terminal voltage regulator. This unit charges the battery in the 13.2-14.6 volt range everytime I've tested it with a DVOM. When the engine is shut down the field coil inside the VR stays powered up causing a 0.3A draw on the battery which over a day or two in cold temps causes the battery voltage to drop to the point it has to be jump started. I think the problem is due to improper VR/ Alternator connections. I have searched the net all over trying to find a correct wiring schematic for the VR but I come up out of luck. I hope you gentlemen can bail me out. Thanks!
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
