Posted by D Slater on December 02, 2012 at 16:54:47 from (184.15.16.54):
In Reply to: Throttle Problems on M posted by bhodgden on December 02, 2012 at 15:53:44:
On top of the governor is a cover with a steel pipe and 2 screws holding it on. Also need to loosen the pipe nut on the end of the pipe at the head. With the cover removed see if the linkage rod is moving the shaft going to the carburetor when operating the throttle. If its moving, the shaft is probably not connected right on the carburetor end. Remove carburetor and look for a notch that connects with the tang on the shaft from the governor. If its not moving see if the lever on the back of the governor housing is moving when the throttle is. If its moving and the throttle shaft to the caburetor is not. Take the 6 bolt cover off the side of the governor housing and look for a broken spring or something else wrong in there.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
