Your mounting arms are somewhat different then mine and the way they were sold was with the gearbox, PTO shaft and other items that make the basic unit as one part. You then select the tractor mounting kit depending on what make and model of tractor you want to mount on. Mine is a fast hitch model for a Super C and the arms are bent up about 2 feet back from where they insert into the fast hitch. The gearbox is what really makes it look like the Ottawa to me. The gearbox should have a round cast hole where a long handle inserts and I believe held in place with a set screw. That handle is used by the tractor operator to tilt the auger during transport and also to position it when drilling a post hole. You might have a tractor mounting kit on yours for something other then the tractor you have it presently mounted on and might have been modified some time ago by a PO. Good luck and they are certainly a good unit, Hal. P.S. I live over by Rolla, Missouri and have quite a bit of literature on these augers I would share with you if you are over this direction in your travels.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
