The pump produces about 1200psi, at usually between 9 and 10 gpm. To get log splitting power, your cylinder is going to need to be in the range of 4 to 5 inch diameter. It will take a bit of time to extend and retrace (especially if the tractor is not running wide open) with a guestimate of 10 seconds stroke time (about 16 inches) it might seem slow compared to a self powered engine driven splitter with 2 speed hydraulic system. It will be fine unless you are doing commercial amounts, or Gnarly ash or other ropy hard to split rounds. To make the remote supply power the lever regulating the remote should be bungied in the direction that supplies pressure to the pressure inlet of the splitter, and the single or double acting control on the tractor valve should be in double acting position, allowing the discharge fluid to return. Jim
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
