Farmall Tractors Discussion Board
Re: IH 656 Hydro pto problem
Posted by Milan H. Dilworth on January 01, 1999 at 12:51:53:
In Reply to: IH 656 Hydro pto problem posted by Tom Moran on December 29, 1998 at 19:30:31:
A small pin in the bottom internal part of the PTO control valve will sometimes break. This lets the part of the valve remain dormant, and no pressure is ever built up and directed to the PTO clutch. You can check to see if this is the problem, by taking out the plug below the PTO valve. Be sure to catch any pieces. A tapered valve piece, and spring, along with the thin rod which connects the bottom spring seat will fall out if the thin pin has broken.
You may need to remove the PTO unit to fully disassemble the valve. I repair this problem by using the extra stiff wire of an old choke cable. Send me email direct if you need a better idea on how to proceed.
Post a Followup
: Re: Re: IH 656 Hydro pto problem
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
