F regulator to F on generator A or G on regulator to A on generator BAT on regulator to ammeter L on regulator (if used) to light and ignition switches
To test generator/ regulator:
If you have a volt meter, check battery voltage with engine off. Start engine and bettery voltage should increase at least 10%. if not
With engine running, ground F on generator. If charge increases suspect defective regulator section in the regulator or associated wiring/grounds.
If still no increase, leave F grounded and jumper A on generator to BAT on regulator. If charge increases suspect cut out side of regulator. If still no increase in charge suspect generator/wiring/loose belt.
Charging circuit will wire the same on 6 or 12 volt.
Ignition circuit with 12 volt will require an additional resistor in the wire between switch and coil or a "12 volt No External Resistor Required" coil
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
