I guess I wasn't clear, the tractor starts and runs fine now that I charged it.
The problem is it doesn't seem to be charging. Checking the voltage with it running I only see 12 volts. IIUC a 12v system should be near 13.6-14.
What I am saying is it is only recieving 7 volts before charging. How do I know if this is from the charging system or if that is what the battery had in it when I checked it? The real question is how do I know if it is charging. In my head it seems like even if the battery was dead it should still read 12+ if the tractor was running bc the gen is putting out that much voltage. Do I have a problem? (besides the battery, I know this is probably bad now, but there had to be something that caused this problem. I will load test that when I get it to a tester)
I forgot. If I do have a problem how do I isolate it without just throwing parts at it starting with a VR then to a battery then to ???
This post was edited by sflem849 at 10:55:59 12/20/09.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
