Joe B2. I would never run a 5/16th tap in such a hole unless it looked perfect to begin with. And then it would be a bottoming tap. I think Mike thought he could cheat his way to good threads.
Under some circumstances, I might cut flutes in a higher grade bolt and use it like a tap to see if I could get the remaining threads to move. That bolt won't break but if it did, it could be drilled out.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
