Yes, the steering cylinder is "inside" the gearbox. If you look at the gearbox from the "passenger" side, you'll notice a protrusion sticking out the back side with a couple of hydraulic lines running between it and the steering column. That's your steering cylinder, has maybe a 4 inch stroke, but about the same bore. Inside the gearbox it's attached to a rack that meshes with a gear sector on the right side output shaft.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
