Farmall Tractors Discussion Board |
Re: F-20 Int-Ex manifold
Posted by Redfan on October 28, 1999 at 04:51:17 from (203.87.53.9):
In Reply to: F-20 Int-Ex manifold posted by Dean E. on October 27, 1999 at 15:04:45:
Dean, the manifold you mentioned came off the farmall regular would most likely fit the F20, but personally I'd be hesitant in using it.The "brass" carb. you have would be the same as was used on the 15-30 and 10-20 Standard tractors, and in efficiency terms, no substitute for the carb used on the F20. I would have thought a manifold for an F20 shouldn't be too hard to find.Regards, Redfan.
Post a Followup
