Farmall Tractors Discussion Board |
Re: 350 Utility
Posted by Don H. on October 08, 1999 at 16:14:34 from (152.163.197.81):
In Reply to: 350 Utility posted by MrGadget: Harold? on October 08, 1999 at 13:44:03:
Your tractor appears to be an International 350 utility made in 1956. Serial numbers on that series began with 501 so yours would have been the 575th built. The difference between Farmall and International is only in the style of the tractor. IH called row crop tractors "Farmall" and utilities, standards, construction models and maybe some other specialized models were referred to as "International". The 3 pt arms for yours were an aftermarket product so your fast hitch tractor could accommodate other 3 pt attachments. It was not a 3 pt hitch tractor but just used a conversion to make it work with 3 pt implements. I have those for my 350 high utility and they work just fine. The rest of your description sounds like a regular 350 utility. The location of the hydraulic ram for the drawbar is correct. It might have had live pto because that was an option on the tractor and many were equipped that way, although I have seen some that were not. Good luck with your tractor. I think you will like it.
Post a Followup
