Farmall Tractors Discussion Board
Re: Re: Re: Re: Farmall Cub carburator
Posted by RKS on May 13, 1999 at 20:52:42:
In Reply to: Re: Re: Re: Farmall Cub carburator posted by RKS on May 13, 1999 at 20:40:11:
might sound silly, but if you find the problem with the float and solve it - - I believe there is no way I would pay for another carb. I would first try putting it together, and then I would use some type of gasoline resistant silicone sealer and smooth it around the gasket where the upper and lower bodies meet. Don't forget to put that little venturi section back in before doing that. To test the float, blow in the fuel inlet and slowly turn the carb upside down. Listen for a "clink" which indicates the float has closed on the float valve. You should then not be able to blow into the carb. Now, while blowing, turn it right side up again, and notice you will be able to blow into it again. Repeat until you are reasonably sure the float is free-moving and doesn't hang against the wall of the float chamber. I think it will work. RKS
Post a Followup
: Re: Re: Re: Re: Re: Farmall Cub carburator
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
