Posted by Aaron medley on October 11, 2012 at 18:48:55 from (174.50.208.252):
I just purchased a cat 943 loader and have a few questions that I need some help with. I was doing some mild brush clearing today and had the machine show signs of overheating a few minutes after I started. I quickly made a dash toward my shop and the machine heated to approx. 220 deg. I quickly shut down the machine and found the fan belt was off its pulley and realized this was the problem. I easily reinstalled it on the pully and started the machine. The machine quickly cooled to a running temp to 160 deg.and everything appeared ok. I ran the machine 20 minutes after this and everything seemed ok. My questions are: does this belt come off easily with running this machine and is it very susceptible to small sticks and debris displacing the fan belt. Also, will a brief overheating of this machine cause any harm to it? I'm a novice with this machine and any advice would be much appreciated. Also, is it normal with this cat for the motor to pull down when picking up a moderately heavy object and stop lifting?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
