Posted by LJD on October 04, 2012 at 15:22:54 from (75.213.46.238):
In Reply to: JD-350 steering posted by Cal Innes on October 04, 2012 at 14:34:01:
Steering problems in crawlers are just about never just "simple adjustments."
With the 350. When you pull back on the steering lever . . . first it decluthes (dis-engages power to the track) and then second . . . it activates a brake as you pull further.
You've got to figure what your problem is. Is there is power to the track all the time - or it is just not braking?
If you run the crawler up a steep incline in 1st gear and then slowly pull back both levers - there should be a point where gravity will let the crawler roll backwards down the hill - even though it's in 1st gear forward and the foot clutch is "up." If it won't roll backwards - it's not declutching. If it DOES roll - then pull back the levers all the way and see if it then stops like you just hit the brakes - because you just DID hit the brakes.
In most cases - there dry-clutch crawlers have stuck or slipping clutch disks AND bad brake bands. On top of that -they often have rusted-stuck linkage.
To test the linkage - hold your foot down hard on the foot-brake pedal and then try to move the right steering clutch lever back and forth. If it won't more without making the brake pedal move with it - it's stuck.
9-10 times from what I've seen - if an owner says "it just needs a simple adjustment" . . . you can bet it needs MUCH more then that. Often $1000s more worth of work unless you do all the repairs yourself and then still - not cheap.
I guess that's one nice thing about Oliver Cletrac and Case 310 and 350 crawlers. No steering clutches at all. Brake bands yes - but they ride in oil and cannot rust.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
