Posted by NCWayne on October 01, 2012 at 10:53:02 from (69.40.232.132):
In Reply to: Case 310 dozer-no fuel posted by MI AC Parsons on October 01, 2012 at 10:12:04:
Have you disconnected the line to the carb? Reason I ask is that a stuck needle won't allow the fuel to get into the carb even if the pump is pushing it up to it. That said if you have fuel to the pump and none going through it it sounds like the pump needs to be replaced or rebuild, but if it is pumping but the fuel isn't getting into the carb then you need to be looking at giving the carb a little TLC instead. One other thing to look for is some fuel transfer pumps have a filter screen built in. Not sure wether the one your's would have one or not, but if the cover on the pump diaphram housing is removable then it's worth a shot to take it off an check. I have seen that filter get clogged and cause the same problem. Hope this helps and good luck.
Today's Featured Article - The Day Mom Drove the 8N - by Brian Browning. My Dad was wanting to put in a garden but couldn't operate the 8N and handle the old horse drawn plow he had found and rigged up to use with the tractor. Well, he decided to go get Mom out of the house and have her drive the tractor while he walked behind the plow. You got to understand that while my Mom is a hard worker who will always help whenever she can... she had never operated farm machinery before that day. Dad got her out there, explained how the clutch was the same as in our o
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
