Posted by MMEd on September 15, 2012 at 13:24:14 from (65.5.210.56):
Still looking for a D5 / D6B / D4D. Found a reasonably nice D5 S/N 94J1737 but it appears to have a clutch issue as well as right brake / steering clutch issues. Its a nice machine otherwise - starts reasonably easy and undercarriage in decent shape. Seller has owned for several years and engine was rebuilt a year or so ago.
Question is how much problem would I be buying assuming it has main clutch issue. It grinds gears when going from Fwd to Reverse but only if you stop in Neutral or move lever slowly thru Neutral. Also grinds gears when shifting 1st to 2nd etc. I am assuming its not adjustment as seller would have likely fixed that before letting me try it.
Second question is steering. It steers Left great. Brake and Steering Clutch seem fine. But Right Brake is lower than Left and with Brake all the way down and Steering Clutch all the way back, sometimes it refuses to steer - just keeps going straight with some scraping noise. Other times it starts to steer with a clunk but then steers ok to right.
What are likely failure modes and repair costs. I"m guessing R&R brakes and Main Clutch ????
Or am I better off with a similar, but older D6B with no obvious issues for $2500 less. No known engine rebuild on the D6 but neither machine appears to have been abused.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
