There is a pointer bolted to the to the static shaft of the idler gear that drives the pump gear,one end points at the camshaft mark and the other at the pump drive mark,you need to be sure that #1 cylinder is on compression stroke,the flywheel at TDC, the pump gear mark should now line up with the pointer, go anti clock half a turn and come up to the 8° mark and the pump match marks should be lined up.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
