Why are you rearching for a rebuilt instead of rebuilding it yourself ?? To my knowledge , there is only one part that isn't available for it anymore.. That's the Torrington input shaft bearing in the pump housing..They have a replacement bearing that isn't as long and uses a spacer for length.. The replacement also has less roller bearings in it..I don't like it , but it does work.. You can get clutch parts aftermarket as well as bearings to lower costs..Sure , it's not a walk in the park to rebuild , but if you can find an old [ seasoned] former Deere mechanic, you have an ace in the hole..If you were closer , I'd do it.. I've done dozens of 450 HLR's in my career..Much of the sucess is in the set-up and adjustments of the HLR transmission.. Poor adjustments are the sucess/failure of this job..adjustments when the transmission start getting harsh are sure service life extenders.. That HLR should shift at wide open throttle without touching the clutch pedal at all..On the high to reverse shift , it should just pull you off the seatback..
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
