Posted by gemdozer on June 24, 2012 at 08:52:44 from (69.156.162.119):
In Reply to: HD9 Ring Gear posted by J.R.B. on June 23, 2012 at 21:06:43:
I had some 371-471-671 power unit and the flywell ring gear was more hight and on HD9 with 471 DETROIT you should have 102 teeths and I have 2 good one on racking and the # is 4341292 and some ring gears too are 103 and 118 teeths.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
Looking 4 set 9 bolt hubs 3 1/8 inch to fit 60 to 4010 jd
[More Ads]
