Posted by Herm00 on June 21, 2012 at 20:02:42 from (75.168.110.248):
Taking the motor apart on my 1000c crawler because I suspected a blown head gasket. I took the valve cover off and noticed the a push rod missing on and intake valve. It was down in the hole so it is probably broken. I aslo took the head bolts off to pull the head. We were unable to break the head loose from the block. We sprayed some lube on it to soak over night. Where can I get a push rod? Is it the same as a Massey 55 or 555? What is the torque order and lbs on the head bolts? Any help would be great.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
