Posted by jm. on June 13, 2012 at 18:53:15 from (75.105.64.39):
In Reply to: int 125e tracks posted by tim in alaska on June 11, 2012 at 22:33:20:
Tim the other two have pretty well covered it. If the rails have internal wear too the point that the adjustment is out you might get 250 hrs by removing ONE link but you will need to leave the worn sprockets on the machine. New sprockets on the worn rails just don,t work. I have never seen one that was worn enough to remove two links. Your smoke could be, rings, low compression, weak injector, ect. I thought you had already purchased the unit. LOW oil preasure and destroying the lower (crankshaft) is the only real alibi that the 125 had. When you go to looking for rails TD 8e and some 8C rails will also fit. New off brand rails are avl..
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
