Check none of the circuit breakers have popped, all the gauges are fed by a common power supply when the key is switched on,ground is made through the respective sender units,where the loom connects to the back of the instrument panel there is a multi plug,the contacts are a likely source of the problem,unplug and replug it a few times and see if the gauges work again,if that does not work you will have to find the wire coming from the ignition switch and test its continuity to the multi plug,if thats good check the circuit on the board for a break.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
