Posted by AJ. on May 11, 2012 at 14:42:02 from (92.4.143.172):
In Reply to: JCB Clutch issues posted by JCBBob on May 11, 2012 at 06:03:13:
I"m in the UK and am familar with JCB"s but there is a problem export machines are badged different than the ones for the home market,the machine I think you have would be an early 3CX here and there is as many models of that machine as days in a month,the mechanical clutch cut out is the only clue I have as to what you got,the machine would have a Borg Warner Velvet Shift shuttle,the F/R is cable operated,the clutch dump valve has a mechanical linkage,there is adjustment on the end of the valve that should be set to .010" between the adjustment bolt and the lever that pushes it,when the valve is pushed in oil that is holding the clutch pack compressed is released and the clutch disengages,check that clearance and make sure the linkage is pushing the valve in all the way,for the valve adjustment get a second person to move the F/R lever and you will see the control valve lever moving,in the centre is the adjusting bolt,you need two 7/16 wrenches,loosen the jam nut and turn the bolt till you have the .010",about the buzz it must be a bare wire grounding when you move the lever,look in that area,move the loom a bit. Good luck AJ
Today's Featured Article - Search For Spares - by Anthony West (UK). Following on from the aquisition of the old Fordson F, I was very much in need of spares. As a novice though I didn't appreciate the fact that there were so many Fordson tractors made, that all the other makes seem rare by comparison. As far as I was aware a fordson was a fordson and it was only through trial an
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
