Assuming the 850 has a setup similar to a CAT, there is a scavage oil line that removes leakage from the torque converter that would otherwise stay in the housing. If the oil level gets high enough to reach the spinning converter, it will cause things to heat up like your talking about. Too the high oil level and heat can cause leakage past the seals causing the oil tracks your seeing. That said, if the problem I have discribed is what is happening, I have no idea where to begin looking on your machine to do a repair.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
