Posted by Mike (WA) on May 01, 2012 at 12:37:43 from (69.10.196.49):
Bought an OC4 diesel, with brand new tracks. After running it a bit, it ruined the center rib on the left front idler. Problem appears to be that the grousers (growsers?) are a little too wide, and the blade arms are bent a little to the left- so the blade arm pushed against the track, causing the center rib on the idler to wear off.
So I'm going to get the blade arms straightened, but I was also wondering if there would be a problem with cutting off about an inch on the inside of each grouser. Could be done with a jig, and a plasma cutter.
Can I get away with just removing an inch on the inside, and leaving the outside as is? Track would have more grouser on the outside than on the inside, is that going to cause a lot of trouble? Would sure rather get away with half the cutting, if I can.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
