.Your dash gauge is NOT the transmission operating pressure, operating pressure is checked on top of the transmission case. TEST that pressure, F,N,R,1,2,3, cold, then hot, record the readings. Compare to spec. What Roy says is right. But I have found There is a system relief valve threaded right into the pump. I've lucked out on some units, when that pressure was reading low, to set up or replace that relief valve, bought me a little more time/use. I could never figure out why Deere didn't put a true transmission pressure gauge in the dash.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
