Posted by Bob/Ont on April 25, 2012 at 13:05:42 from (70.26.61.215):
In Reply to: Re: By the way posted by chrisBarwick on April 24, 2012 at 19:39:46:
Chris, check your valve for markings JM mentioned. Don't plug any relief valves. With open center valves you need to close the open center path to harness the hyd power. The open center path goes to the return after the last spool in the valve bank. To use power beyond the center flow needs to be seperated from the return untill it goes through the remote valve and then the remote valve's return also sent back to return. This gets a bit trickey to advise upon here not knowing your valve because you want to keep the flow to the remote valve seperated from the main valve's return to prevent pressure backing up to places in the main valve it shouldn't go. The only power beyong I have ever set up required a plug be installed inside the valve under the P B fitting and the remote valve return flow came back to another fitting in the main valves return. This is the best I can do without seeing your valve. Later Bob
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
