Crawlers, Dozers, Loaders & Backhoes Discussion Board
CAT 416 Boom weak? Cyls? Valve? Oil?
Posted by Jeff Hoo on July 26, 2011 at 07:28:01 from (75.227.130.212):
90's Backhoe, lightly used.
All other hydraulics seem to work fine, but the boom lift cylinders suddenly barely have any oomph.
If the arm is even half extended, they can't even lift the boom.
How do I tell if this is a cylinder/piston leak? Or spool valve problem? Or maybe bleed or fluid problem. Need higher weight oil?
Using Valvoline AW32 hyd fluid now (100F here, too)
Thanks
Jeff
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: Super WD9. [More Ads]
