Posted by scotc on November 13, 2010 at 12:16:10 from (69.10.12.41):
In Reply to: FORD 555 shuttle posted by tomca on October 17, 2010 at 13:40:02:
Will it back up once it warms up? Is there a load on the motor when it won't reverse? If there is little to no load when it won't move, and it does reverse once it's warm, it's probably got some bad O-rings in the hydraulic reverser. You might be able to pull the fuel tank and stand on your head to get to them.
The differential lock is operated by a spring-loaded button, as is the transmission disconnect, unless there is a switch, or was a switch, on the top of the lever for the front bucket.
The disconnect allows you to shift between forward and reverse while keeping your RPM up, like while scooping or dumping dirt, or waiting for the bucket to come up enough to clear the side of a truck.
Also, the straight 555s, the A, and maybe the B series, you pull the T handle up and give it a 1/4 turn, then hit the brakes to set them for parking. If I remember right. The late B series and C's used a lever mounted behind the bucket control lever to set the brakes using a cable, instead of locking the pedals down.
Also, if you have a 555B, and when you order parts, if they are the wrong ones, order parts for a 555C. The last couple months they built the B's, they were actually C's with different sheetmetal. We were one of the lucky ones who got one of the transition models. A dealer should be able to tell you if you have one of those machines using the serial number.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
