Posted by 135 Fan on January 09, 2008 at 23:40:53 from (68.149.41.128):
In Reply to: tree pusher posted by Sam in WA on January 09, 2008 at 20:17:06:
Heavier wall tubing and heavy gusseting. If it's bending, it's not designed or built strong enough. Try to use shorter lengths of tubing with some more corners rather than using longer straight pieces of tubing. The corners will add strength and can be gusseted which will give even more strength. You could put internal stiffeners in the tubing but this would have to be done before the assembly is welded up. Some slots could be cut length wise in the tubing to attach the stiffeners and then the slots could be completely welded up like a plug weld. Additional flat bar or angle iron could be added to the sides of the tubing as well. A lot of heavy equipment attachments are made with solid plate in order to be strong enough. Often a high strength steel Like T1 is used. Dave
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
