Posted by AJ. on January 01, 2008 at 07:42:11 from (195.93.21.130):
In Reply to: Dozer Brakes posted by -Tim MccCarthy on December 29, 2007 at 20:32:27:
Maybe the brakes are adjusted too tight and not allowing the clutches to disengage,the clutches should be fully disengaged before the brake comes on,does the machine stop when you press both pedals,if it does not the clutches are not disengaging and you would need to sort that first,let the brakes off again and then see if the machine stops when you press the pedals if not there could be an issue with the control valve or oil pressure that needs seeing to. AJ
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
