Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: JCB 1400B FROTHING TRANNY FLUID
Posted by ajk on November 23, 2006 at 03:13:49 from (195.93.21.130):
In Reply to: JCB 1400B FROTHING TRANNY FLUID posted by M Hamilton on November 22, 2006 at 15:10:53:
There are two types of shuttle,in the mid eighties JCB changed from using Borg Warner shuttle box to ZF,badged JCB,the BW shuttle had a cable operated forward/reverse lever and the ZF was electric F/R,a short lever stork on the left of steering column,if you got the ZF there is one spin on filter on the left side of the box and one suction strainer under a plate near the filter,if you got the BW shuttle there is no external filter but there is a pickup strainer in the little sump pan on the bottom,the pan has to be removed to service it,there is an o"ring on the pipe of the strainer if its gone hard it could draw air,the most common cause of the fluid coming from the filler of the BW shuttle is an inline check valve on the box,there is a pipe that goes from A to B on the box,in the middle there is a piece of hexagon bar about 3/4 inches,inside that bar is a ball and spring,the ball can jam or the spring break and that can causes the fluid to come out the filler,it is best to take off the whole pipe than try to take the valve part from it to inspect it,the valve comes apart,I have never known the ZF to throw the oil out so i can"t make any suggestions about that except to clean the strainer and change the filter,in both cases have a look at the lines that goes and comes from the cooler,see that they did not get a knock and are kinked and blocking the fluid flow,as was said in the other post the fluid level is checked with the engine on low idle. Good luck AJ
Home
| Forums
Today's Featured Article -
Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
Latest Ad:
Super WD9.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
