Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: 931B brakes
Posted by 135 Fan on October 24, 2006 at 22:31:27 from (68.149.51.133):
In Reply to: Re: 931B brakes posted by Bob/Ont on October 16, 2006 at 06:22:21:
Finally had a nice day to see what the Cat is doing. The bearings on the cams for the steering clutches seem OK. The right clutch was a little loose on the mounting so I tightened it. The ground was wet and it steered good. I was using the backhoe for a couple hours and it still steered good. The pedals do go down almost to the end though. Before when I was using the loader the right brake would not turn at all when hot. I think I just need to adjust the brake bands. I got the Cat instructions copied and they say to measure all the linkages and adjust to specs before adjusting the brakes. Do you advice this or should I just tighten the brakes? It looks like I'll have to pull the seat off to get enough room to adjust them. Is there any common problems when adjusting them? I need to do a bunch of drainage work before it freezes and don't want the machine tied up till spring. Also what would cause pressure in the trans? Cat told me there was a bulletin on the breather. I took it off and cleaned it with brake clean. Should this be sufficient? Your assistance is very appreciated! Dave
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
