Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: Cat D6C transmission problem
Posted by Len Sholes on September 01, 2004 at 09:34:02 from (24.207.52.55):
In Reply to: Cat D6C transmission problem posted by Richardt on August 31, 2004 at 10:32:27:
Richard it sounds to me that you have a pressure problem. That is when the oil is cool you have pressure but as soon as it warms up you lose it. This is the reason you can not get the shift lever into gear. I would put a pressure guage on the trans pump and see what you have. You should have around 300 to 350 psi. The plug on the pump is a 1/8 inch pipe thread. If you have the floor boards off and take the small cover off the top of the transmision there are two pressure ports on the pressure control valve. The one closet to the angled corner is your speed clutch tap and the other is your directional pressure port. Check with transmission in gear and at hi idle. The speed clutch should be 300 to 350 psi and the directional clutch should be 50 to 60 psi less than the speed clutch pressure. If your pressure is down I would suspect the trans pump is worn out. It is a gear pump and if you end up replacing it make sure you clean the magnetic filter, replace the trans filter and prime the pump before staring up the engine or you could have a pump failure due to lack of lubrication.
Home
| Forums
Today's Featured Article -
Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
Super WD9.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
