I have a 450C that is doing almost the same exact thing except the right side will quit pulling when I pull the left lever sometimes Usually when I am on a slope. But then it will work fine for awhile. I can drop the blade in the dirt and both tracks will just dig. I have checked the pressure it is running about 175psi but it does not react like the manual says it should it drops to low when shifting and takes to long to come back up. Shifting from forward to reverse it seems sluggish. I just changed trans fluid the screen was horribly dirty. Any ideas what else to check I suspect that something is stopped up since the pressures do not react like the manual says it should.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
