1. Tried to stall it in 3rd but ground was to soft if I let just one side out it would just spin the track. Both left and right side. If I let both out at the same time that would stall the dozer.
2. When rolling it backward both sides brakes worked just fine.
3. When on hill and letting both levers out slowly at the same time I did find that narrow spot were it began to roll backwards.
Ran it hard for a half hour today and everything ran perfect. Both sides worded great had no issues. So not sure why some times it works great then other times it does not. Want to check the fluid for each side. Where do you check the fluid? Looked and could not find it. If low what type of fluid should I put in? If it is low would that make it slip or not engage? The dozer sat for over a year before I bought it perhaps it just needs to run a bit to unstick everything? I know I am reaching there....
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
