I've been through similar variations of these problems. These are dry clutches and don't always take well to aging. With rust and deterioration the clutches sometimes don't fully release and when you step really hard on the pedal the discs groan from too much friction. I've also had it where proper clutch pressure does not fully return due to a tiny spring being broken in the steering valve. There is a small pipe plug on each side of the outer housing facing the tracks. If you attach a hose with a pressure gauge there capable of 300 lbs start the machine and depress the pedal on the same side as the hook-up, you must have a minimum of 220 lbs for the clutches to release and must return to 0 lbs as soon as you take the foot off the pedal.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
