Thanx. This morning, I moved the rod, back and forth, many times. Worked the Y back and forth exercising the spring. Afterward, I sat and attempted to start the engine on gas. It fired ignite a couple of cylinders, and then died. after a few attempts, I realized that the engine was now getting gas. Through trial an error, I figured the timing in relation to the plug wires on the cap were 180. So the engine was firing 180 out.
I reversed the wires on the cap, and then started the engine with success. However, it wasn't operating good enough. So, I went to the gears, inside the mag, and moved the larger gear one tooth. Started the engine and it started, operating good. Had no problem switching to diesel. Relief, relief. Now, I am to trouble shoot the generator, as there is no movement on the amp gauge. The voltage reg. is new. So, will test the gen. for output.
Thanks AL, for your input. I remain appreciative. Thanks to all who gave there input. Tho
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
