What does "doesn't steer" mean? It does not brake? Does not de-clutch? Or does not push? All three must happen for good steering and all can be separate issues.
When adjusted correct with all parts working - clutch is fully engaged and brake is fully dis-engaged when not touching steering lever.
When you start to pull on the lever - clutch must disengage BEFORE brake starts to grap.
Pull hard and break grabs hard.
An easy test. Park on a steep hill, put it in gear (with engine running) and start going up - letting go of steering levers. Then - slowly pull back on them. If all is adjusted correctly - you will get to a point that even when in gear - the crawler will roll backwards easily. Pull a little more and it will stop and the engine will sound just the same (not laboring as if the clutches were dragging).
To adjust - first you adjust the brake-band size by cranking the size-adjuster tight and then back off one turn. Then you adjust the linkage inside the clutch-housing to get brake and declutch timing correct.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
