Add oil to it... It isn't gonna hurt.. It will either leak externally on loose lines , rubbed thru lines , leak out of cylinder seals under the seat or leak thru the pump shaft seal into the engine.. If the engine oil level goes up a good bit , the shaft seal is leaking into the crankcase via front cover to sump.. When it's operating correctly , there will be a slight vibration felt in the steering levers when you pull on it..
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
