Posted by stevessuperduty on November 09, 2013 at 04:04:13 from (70.193.196.87):
i have a john deere 710b backhoe with no charge oil pressure to main pump at idle but ok flow at operating rpm. hydraulics all work fine if kept at a high rpm but as soon as you idle it down hydraulics begin chattering and the pump starves for oil. I have a manual but honestly it has my head spinning around trying to check 30 different check valve, relief valves...etc. Clean fluid, clean filters, clean pick up screen. Put gauges on charge oil port on pump and 0 at idle and 50-70 at higher rpms. any help would be greatly appreciated.
Today's Featured Article - Tractor Traction - by Chris Pratt. Our first bout with traction problems came when cultivatin with our Massey-Harris Pony. Up till then, this tractor had been running a corn grinder and pulling a trailer. It had new unfilled rear tires and no wheel weights. The garden was already sprouting when we hooked up the mid-mount shovel cultivators to the Pony. The seed bed was soft enough that the rear end would spin and slowly work its way to the downhill side of the gardens slight incline. From this, we learned our lesson sinc
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
