Posted by NCWayne on November 07, 2013 at 22:29:17 from (173.188.169.54):
In Reply to: Re: Case 350 smoking bad! posted by Case crawler owner on November 07, 2013 at 06:07:15:
There are three colors of smoke, black, blue, and white. Black is from incomplete combustion, white is from raw/unburned fuel, and blue is caused by burning oil. The most usual cause is from valve stem seals leaking. This can be caused by old/hardened valve stem seals, or worn valve guides causing too much play in the valve stem, to the point that the seal can't do it's job. Too it can come from oil getting sucked past the piston rings due to the cylinder walls/rings being glazed, etc.
In your case I don't think blue smoke is going to hurt a thing. In fact if you had a cylinder missing for awhile, if you run it long enough with all cylinders firing again, the smoke might go away on it's own. Good luck.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
