Posted by NCWayne on August 13, 2013 at 21:28:33 from (98.21.228.82):
In Reply to: NH skid steer parts posted by Nathaniel Watts on August 13, 2013 at 18:35:53:
Unless they are a propriatory design for NH, any Eaton distributor should be able to get the parts as long as you have the model number, etc off the pump. That being said, what part is leaking? I ask because of the shaft seal is leaking you are more than likely going to need a new pump. I say this because the biggest cause of the shaft seals leaking is a grove being worn into the shaft. Hope that's not your problem. Good luck.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
