Might be worn out or might be something simple (if you're lucky).
#1 - pull the floor pan up on the "driver's side" and make sure the valve-arm that is hooked to the clutch pedal is returning all the way. Often when the return spring gets oil and/or there's debris in there- is it blocked from returning all the way.
#2 - try opening up the "rate of shift" adjustable jet with a screwdriver. That can sometimes make a huge difference.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
