If your shop there can straighten the shaft WITHOUT DAMAGING IT, then have them do so. As far as the bolt & stripped hole, have them bore & tap for the next size larger bolt. Do N O T weld on the shaft.
Use Caterpillar GREEN Cement INSTEAD of Locktite. With Locktite, even after it's "set" the bond can still be broken. With "Cat. Green", after it's "set" the bond is PERMANENT; The only thing that will get two parts apart that have been bonded with Cat. Green is a CUTTING TORCH. - I know, BTDT!
Doc (Sr. Underground Top Millwright / Mine Maint. Mechanic)
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
